Zamieszczone przez ciaglejade
...wyposazenie to cala masa kodow ponizej(jest ich cala masa nie spotkalem na razie rozpiski w internecie, na gorze pierwsze trzy to oznaczenie silnika (np. AGR, ALH), drugie trzy to oznaczenie skrzyni (np.EGS, ERF).
[ Dodano: Nie 30 Lis, 08 22:50 ]
...tutaj masz rozpiske wyposazenia z mojego auta´:
X3B national sales program Spain (FBU)
A8D luxury equipment
G0C 5-speed manual transmission
K8D Station Wagon Variant/Avant
T8U 4-cylinder diesel engine 1.9 L unit 038.G
AZ0 vehicle with standard production scope
B0A component parts set without country-specific design requirement
B15 type approval Spain (Andorra, Balearic Islands, Canaries)
C00 operating permit, initial registration
C6F alloy wheels 6J x 15 style not designated; 1J0 601 025 offset 38 (five-hole)
E0A no special edition
F0A no special purpose vehicle, standard equipment
G33 front shock absorption
H6S tires 195/65 R 15 V
J0L battery 340 A (70 Ah)
L0L LHD vehicle
L09 suspension range 09
MN0 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIEU 3 base engine is T8U
N2M fabric seat covering
QA0 without child seat
QG1 service interval prolongation
QJ0 without aluminum/chrome work package
QS0 without electronic map cooling system
QV0 w/o TV reception/digital radio reception
Q1A standard seats
U1A instrument insert with km/h speedometer,clock, tachometer and trip odometer
VC0 w/o remote-controlled garage door opener
VK0 air duct, standard
V0A tires w/o specification of tire brand
0AE front stabilizer
0A2 four doors
0BC rear stabilizer
0CH vehicle class differentiation 1U0
0EJ installation differentiation for transmission MQ 250 vehicle components
0FA standard manufacturing sequence
0F3 fuel system for diesel engine
0GE emissions concept EU 3
0G4 cable gearshift
0KA without stickers and badges
0L2 electric throttle actuation
0NB nameplate set in base trim
0N5 standard rear axle
0RA without ignition/starter switch locking system
0SU labels/plates in Spanish and Italian
0TA without floor mats
0VD Spanish owner's manual
0YZ without determination of weight categoryfor rear axle
1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 without towing attachment
1EX VIN plate
1E0 without activated charcoal canister
1G2 steel spare wheel with original equipment tires
1H0 without proportioning valve
1JH rear shock absorption
1KP disc brakes, rear
1LS front disc brakes with integrated adapter
1MP steering wheel for airbag system
1NL covers for alloy wheels
1N6 power steering
1PC wheel bolts with anti-theft protection (unlockable)
1Q0 without mass damper for steering wheel
1SA without additional engine guard
1T0 w/o first aid kit and warning triangle
1X0 front wheel drive
1Z2 increase in initial standard fuel filling
2B1 additional exterior noise suppression
2C5 axial and vertical adjustable steering column
2D0 without cd enhancing underbody panel
2G8 filler neck module 2 without insert
2LB fuel tank with special material treatment (fluorination)
2UA standard design
2V1 dust and pollen filter
2W0 fuel filler cap
3AF outer right rear view mirror: convex, powered, heated
3BS outer left rear view mirror: non-spherical, powered, heated
3B0 without additional child seat anchor
3CA without partition
3C1 static lap belt, center rear
3FA without roof insert (standard roof)
3GA without cargo area
3H0 without backrest release for front seats
3J7 articulated and height-adjustable headrests for front seats
3L3 height adjustable front seats
3NW rear seat bench/backrest, split folding with center armrest
3QT 3-point seat belts with tensioner and height adjustment, front
3Q1 rear headrests
3S2 black roof rails
3U2 sliding trunk cover
3V0 without child bench seat
3X0 without load-through provision
3ZG 3-point seat belts, outer rear with height adjustment
4A0 without seat heater
4B1 protective side molding
4E0 tailgate/trunk lid unlocking from outside
4GC windshield, tinted with sun band
4KC side and rear windows tinted
4K3 radio remote controlled central locking operated from inside and safe securing
4LA without controls
4L0 non-dipping breakaway inside rear view mirror
4M6 cup holder
4N1 padded dashboard
4P2 rear floor panel module, type 3
4R4 electric rear windows
4SC left vanity mirror with cover
4TC right vanity mirror with cover
4UE airbag f. driver a. front seat passenger
4U1 luggage nets/pockets on backrests
4W0 without cassette and CD storage unit
4X0 without side airbag
4Z3 lockable glove compartment door, with light
5C0 without special body measures
5D1 Remote control and central locking system
5K1 paint preservative (wax)
5TC without decorative inserts
6A0 without fire extinguisher
6E3 center armrest front
6FB exterior mirror housings and door handles in body colour
6KA radiator grille
6M2 load safety net
6N0 without mud flaps
6PA plastic hand brake lever handle
6P1 license plate bracket rear (ECE)
6Q1 plastic gearshift knob/handle
6R1 leatherette gearshift boot
6SC tufted trunk floor covering
6W0 without license plate bracket front
6XD outer rear view mirrors: powered, heated
6Y0 without cruise control warning system
7AA electronic vehicle immobilization device
7A0 without CD changer/CD player
7E0 w/o heat accumulator/auxiliary heating
7N0 without tray on roof liner
7PB platform group class 2
7P0 without lumbar support in front and rear seats
7QA without CD ROM
7Q0 without navigation device
7X0 without park distance control
8AA without radio
8BN halogen headlight for left-hand drive
8CC speedometer sensor without seal (electronic speedometer sensor)
8F2 side turn signal lights
8GD alternator 90A
8K0 without special low beam mode
8L3 roof antenna
8M1 rear window wiper and washer system with intermittent control
8NA without parking light warning light
8N4 windshield wiper intermittent control with potentiometer (four speeds)
8QK key for locking system
8Q1 headlight-range adjustment
8RM eight loudspeakers (passive)
8R1 center high-mounted stop light
8SA taillight assemblies, standard design
8S4 two reading lights front, two rear
8TC rear fog light for driving on the right
8T0 without cruise control system (CCS)
8WD integrated front fog light
8W0 without washer fluid level indicator
8X0 without headlight washer system
8Y1 two-tone horn
8Z5 engine cooling system, type 1
9AK automatic air conditioning with sun sensor
9A0 without taxi alarm system
9BC display and warning tone f. opened doors
9D0 without preparation for two-way radio installation
9J0 without supertone system and tone sequence control
9M0 without auxiliary/parking heater
9P1 seat belt warning light, electric contact in buckle
9Q1 onboard computer
9TB additional warning lights (door area)
9T0 without heated washer nozzles
9U1 brake pad wear indicator
9W0 w/o car phone preparation/installation
9X0 without heated door lock cylinder
[ Dodano: Nie 30 Lis, 08 22:53 ]
2pac ale w twoim dekoderze nie ma kodow wyposazenia.
